auto box
hi zmates my import Z TT auto when cold it takes about 2-3 miles before it warms up and the overdrive kicks in then i have all gears working ok, is this normal for an auto with overdrive? :(
ย
regards mo
changes ok up to 3rd but 4th and overdrives takes a long time to engage but when it hot it works fine, have had an auto box oil cooler fitted and had the levels topped up.
ย
regards mo
There is a temerature sensor in the gearbox which holds off the ovedrive function till the box is at working temperature, this is normal.
ย
Daveman
You Might Have Bad Fluid In Gear Box Or Prob. In The Gear Box Filter.... I Would Change Out The Fluid And Filter.
agree with Daveman, think i read somewhere its 60 deg. mine does the same m8, it wont give full boost either till its warmed up
