N/A -> TT problems (mostly vacuum)
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
first of all sorry for my english im french ;)
I'm swapping a tt engine into a n/a car and i ran into a few problems
This is my first project car and i dont know much about car mechanics, ive learn much since i started the project and solves a lot fo problems myself but now i need your help.
My n/a car is a 95 L/H 5 spd
My tt engine is from a 90-93 R/H auto
mechanical issues
the oil cooler mountings holes doesnt seems to fit anywhere where should it be mount (a pics would be appreciated)
electrical issues
on my 95 harness i have a connector that goes right next to the egr valve
and i dont have this connection on my tt engine... im using the tt ecu do i need to do something about this or just leave the connector unpluged?
Vacuum issues
1
I bought a manual boost controller and I removed the stock wastegate solenoid... there was a hose from (before turbo compression piping) to the wastegate solenoid. It seems like I dont need this connection with my aftermarket boost controller is that correct? Do I plug those holes...
2
I also bought a boost gauge i plug it right on the balance tube... will it work properly. if not where i should plug it
3
With the egr & prvr valve solenoids i copy my n/a engine plumbing but i really like too have a diagram for this since the service manual is not clear about those connections
4
I removed the (wheel well) to find out there was no AIV :confused:
is this critical??? my n/a engine was working great :confused:
5
Where is the boost jets goes (does it matters if there is any, if yes, why)
6
Where the right throttle chamber vacuum (pointing the front of the car) is plugged to...
7
where recirculation valve top should lead (where on the intake manifold)
That's it for now
Thanks for reading this
I hope you guys can help me out ;)
