I have found a pair of R33 GTS-t 4 pots that another forum user wants to sell.... They're going on a Z32 N/A, along with 322mm dia discs (30mm thick). Will these callipers be big enough for the discs?? I don't want spend money and end up having fitting problems etc ..
I am running 19 inch rims so space should not be a problem.
Any advice regarding this will be greatfully received :bow:
Very much doubt it mate, the GTS-T uses 296mm discs (same as our rears) it also uses same front pads as our Zeds as they are both 4 pots, 296 is the biggest you can use on our cars without fitting adapter brackets, so I would say you need brackets making up if you go down this route and the GTS-T calipers ain't no improvement over our TT calipers for you.
19's means you can fit right upto 355mm and then some if you wanted though ;)
Oh and 322mm discs, what are they off ??
cheers
smithy
cheers
smithy
Cheers Smithy!! Discs bought from from Andy P and are brand new & unused ADL's. Now looking for calipers that will match up preferably without adaptors (but will use them if necessary. )
Alternative is to sell the discs and buy set of calipers & discs to match!! Any offers of help out there?? :bow:
