any ideas have a clip with two small holes spring type to fit into lip of bovs on the flange to keep in place..i have used the proper pliers but the dont seem to bend in enough to fit.... :headvswal :headvswal :headvswal
It's called a "circlip" and can be a right pain in the you-know-what to fit. You can get some circlip pliers which will make it easier to fit but only persistence will get the clip into place. They usually fit into a groove in the flange so try pushing one end into the groove and then the other end. My apologies if this isn't much help ...
Dan
you need to purchase some circlip pliers,you can by these at any tool place even halfoorrds,or you can go down the route try with normal ones but be prepared for a blakemans pinch,if im allowed to sau that.or borow mine but i feel ANDOVER IS PROB A TAD TO FAR.
