Lights on alert
Hi Guys
I'm sure when I bought my car a few weeks ago there was a buzzer that sounded when I opened the door after leaving the lights on.
I've had the ding, ding 60mph bell disconnected and now the lights on buzzer doesn't work.
Am I imagining that I had a buzzer for the lights or are the two connected.
Spencer
i can confirm there is a buzzer for leaving the light on, im afraid i can't help you with the problem though
Hi Guys
Spencer
Spencer,
You are not imagining things - there is indeed a buzzer when you leave the lights on. Thing is that it is part of the same warning system as the 60mph bell and so when you disconnected that it will also no longer sound the alarm when you leave the lights on. Best thing to do is to get a speed delimiter and reattach the 60mph bell - that will remove the 112mph speed restriction, disable the 60mph bell (well, actually it doesn't - it moves it much further up the speed range where you're unlikely to hear it) and your lights-are-on buzzer will work again. Speed delimeters can be bought from Luke at the ZCentre (details in the trader section of the forum).
Dan
