r they any good or is it better to do a 2 man job?
Vijay
The Gunsons EZ-Bleed is supposed to be pretty good, uses tyre pressure to force the fluid through, however there is an issue with the lid not fitting the S13 resevoir, and therefore undoubtedly not the Z32 one either.
I'm going to get a spare resevoir cap off a scrapper and bastardize it.
Jezz.
Yeah you're right Jezz. Problem with the cap on the Z32 and probably the S13 is that the cap doesn't actually seal. There would be no point in using the original cap because of this. Gunson do however make adaptors to fit different size reservoirs - none of these fit though biggrin.gif You need to get the universal one - as far as I can see it should work with our cars... Nothings ever easy is it!!!
CheerZ,
Andy
I've used those in the past and whilst they do work it still puts loads of strain on the master cylinder with the pistion moving the full stroke dozens of times. Twice I can remember a master cylinder has had to be replaced because it has packed up during the bleeding process. Of course you could view that as a good thing, becuase it didn't fail when I actually needed it to stop the car/bike.
I haven't used the pneumatic tools but they do sound promising.
