As the title suggests. I need to know where I can get hold of the fuse for my main headlights.
Anyone?
come on, someone must know where to buy a fuse (except Nissan of course)
It should be standard blade fuse (15 amp?) in which case Halfrauds or any good motor factors should be able to sort you out. Are you certain it's the fuse and not the switch mechanism or relay?
Steve :)
'93 UK TT Manual
Steve :)
Thanks,
I'm not sure if it is the fuse, relay or switching mechanism, but I thought I would try the cheap things first.
The problem is neither main beam bulbs come on at all.
Is this likely to be a fuse?
