Power button - 1 long flash before startup??
What does this signify?? :confused:
This is without doing an autobox diag.
Autobox ECU has detected a failure in the AT revolution/speed sensor circuit.
think it all aways does this. when you turn the key so all the warning lights light up is that when you mean? before you engauge the starter?. just been out to mine to check and it does this, and it has just come back from Ztec with FULL REBUILD and i think they would of spotted it if it was something wrong. hth
graeme
or as above must type quicker
Is the A/T light the same as the POWER light though
yes, UK models have an AT light in place of the Power light found in imports.
But Do the UK models have a power function(keeps the revs up)?
