Help
Ok guys so I'm new to these forums. I have three problems:
1. i just replaced the master and slave cylinders and ever since i replaced them, everytime i push the clutch in, it makes a squeeky noise.
2. When I'm driving (especially at slow speeds) my car squeeks too!!!! but if i hold the brake pedal down just a bit to where the car wants to slow down, the noise stops.
3. my a/c compressor is locked up, when i replace it, what besides the reciever/drier should be replaced along with that? (anyone have any good experiences with aftermarket parts? and if so, which ones and where?)
If any of you guys know, I would greatly appreciate it. Thanks
i have the same problem it squeeks when pressing brake pedal like a rusty spring sound,i thought it was low pads and the unit having to go futher but new pads and discs and still doing it???
Try squirting joints with spray grease NOT WD40 as it evaporates after a while !
Have you got thin like shims behind the discs or are the discs ctraight in on there own ? Possibly try putting a smidgin of copper slip on the back of the pads also
You would be best to change all belts while there off and dont forget the gas is poisonous so dont breath it in. Then obviously it will have to be re-gassed ;)
I think you can get anti-squeel pads. Dont know if they work tho!
the pads are hawk and it aint them the piston were soaked in wd40 dont think them put they sound crap when slowing to stand still anyone else help had this problem... :mac1:
