Bovs
ok i bought a set of hks bovs of buddah.. fitting can the be fitted in place of the old resc ones with the right fitting kit or do they have to be on the hard pipe which is best for running.
thank you :nana2:
they can go pretty much anywhere as long as its on a pressure pipe so either on the turbo outlet side or the throttle body pipes are fine, i personnely prefer them where the recircs go?
i was told this is the best place for tickover
TBH the best place is usually where nissan intended them to be so i would go with the oem recircs place :)
ok found this in a old report anyone help were my hks bovs should go???????
Replacing your top intake hose with the Hard one's from Smithy and then modifying them to take BOV'S is the best place to put them as they are closest to the throttle boddies. Other guys fit them to the bottom 2 hoses which is crap because when your throttle bodies close all that air then get's forced back through the intercoolers into the outlet pipe from the turbo before it's dumped! Makes a good noise but you may as well not have dump valves for all the good it does. When your back on the throttle all that air has to then be re-accelerated again causing Major Lag! Get your pipes from
buddah knows for a set of pipes that our mate is selling
