Gauges
Hi to all
can you run from the oem oil pressure to gauges or do you need new sender and what if i want to do oil temp later on????thanks guys :nana2:
you'll need sender that comes with the new gauge.
oil temp can be done by tee-ing into a steel oil pipe or by getting a sandwich plate and both oil temp and pressure will go into it thus keeping your standard pressure gauge on your dash.
Hi to all
very easy to do mate, just remove ur standard one and replace with the one in the kit... its just next to the oil feed for the left hand turbo..
if you need any help PM as i have fitted oil temp, pressure myself recently
Hope this helps!
just be careful when using the crappy plastic feed line for the oil guage , i know of a few cases where they have melted and oil sprayed in engine bay and caught fire so possibly look into getting a braided line something like a aeroquip one.
Coolant temp is better over oil temp.
i will be getting this and boost for pod m8 these three are for the dash,cheers
