cooling issues
dose any one know or have any idea if there are cooling problems with z eds ie leaking caps or prone to blocking up galaries or thermostas any ideas
driving in busy traffic (stop & go) in above 25C weather with the AC on will overheat almost any Zed...especially autos.
airpockets in the system is also common.
also quite common is blockage of waterchannels caused by leftovers of too much sealant/gasket...especially the small pipes from/to the turbos suffer from this.
Do NOT trust the standard watertemp. gauge..it will still be halfway even when the engine is 100C and if it the gauge is showing the engine is hot, the engine is indeed SERIOUSLY hot (>130C) and you should stop immediately and let the engine cool to avoid warpage of the heads.
I had a leaky rad caap. Fitted a new uprated one now. Seems ok. Sure it was over heating due to air locks.
cheers every one
there are two .one at the top left hand end of radiator the othere is a tap at the bottom left hand corner but you have take the belly pan off to get at the bottom one off
were do iget an uprated radiator cap
