door speaker fitting
tried to have inside of door off today to fit speakers. unscrewed all but i didnt want to wrench too much incase of damage. is there ny easier way to fit door speakers?? :confused:
Nope you gotta take the door cards off to get the old speakers out before fitting new ones mate
What about the electric window bits??? Do i have to pop the plastic bits off the inside and detatch them first?? :confused:
i think i saw an faq/how-to on this somewhere
any help would be great...I dont want to bodge it all and have to take it to a nissan dealer to have it all put back on !
remove the electric windows switch there is a screw there, also remove the vertical trim strip that window runs up, another couple of screws there.
Do I do this before i try and take the door panel off? I tried to lever the plastic bit off around the electric window switches with a screwdriver but did not want it to bust
OK hold it there, you dont have to touch the window switches
start by lowering the window.
If you have a jap car with the seat belts on the door. Remove the top and bottom fixings.
Then from the outside you will see a large round cover plate half way up the door post.
remove this and you will see a screw that holds the large plastic cover at the rear of the door. it will then come away with a pull.
You have to remove the pull handle on the pasenger side and two bolts deep in the finger pull on the driver side other than that you should see all the other fixings
When you lift the door cards off you can then unplug the window controls from the inside of the switch. dont forget to bring the window up befor you unplug it.
Good luck,
Chris,,
Mine has a screw where its circled in the picture so you need to remove the electric windows switch, sorry for my short answer, I had to go off to work and tried to answer briefly as you said any help would be great but Dave has put the link up now.
