Hicas???
4ws rite?
Well, thing is...
it doesn't seem to work,
Any ideas guys???
Also, I've been reading a few threads about decatin which shud b ok
as long as the seals are ok,
Is there any way 2 check these seals b4hand?
How do you lnow it's not working bud?
Hicas
Its 4ws but not perhaps the way you are thinking of it. Its a High speed Handling aid, not a parking aid.
It works at speed, turning the rear wheels up to 1 degree, to improving turn-in. It behavior is controlled by computer, and monitors speed and steering wheel movement to determine the behaviour of the rear wheels, inducing the "rally flick" where it flicks the wheels in the opposite direction before turning back the other way,
You rear hicas bushes need to be in good condition for it to work effectively.
Decat/Turbo seals
Without taking out engine, removing tubs and dismanting, no, not really. If its smoking at all now, or is on high mileage it may be too much of a risk.
Most have no problems at all, myself included ...others have had problems almost instantly.
when you removed it did you fit a bar accross where the rear steering rack used to be?
Thats what I did with my Skyline (I have a skyline too) along with a locked diff to turn it into a drift machine lol!
Thanx alot guys, uv cleared things up loads :-)
