Hi M8tey's,
Can anyone tell where to top up the ATF and best way to do it.
Is the atf fluid the same as the diff fluid?
cheerz
Marc
look at the engine from the front
at the back on the left hand side you should see a dipstick ( look behind the engine)
This is where you top it up , i use a rubber tube connected to the atf bottle.
Good quality dexron II oil
Cheerz Bud,
So this is the place to check and top up then?
The only reason I ask is cos Ive heard others talking about getting underneath the car to check and top up ;)
Sorry if I appear a thicko, I'd rather ask than screw it up.
Marc
Np Mate, weve all been there
do a search on atf fluid and will come up with lots of replies
check with the engine runing and gearbox fully warmed up so the torque converter is fully loaded with fluid
you do a fluid change from underneath by removing the sump pan.
You do have to get underneath to check the rear diff and top that up as well tho
.....................The only reason I ask is cos Ive heard others talking about getting underneath the car to check and top up ;)................Marc
I believe that is for manual boxes mate.
Richard :smw:
