Wheel Machining
Ok guys I have fitted some 19s with offset 20
These obviousely stick out a bit about 12 to 14 mm id say... beyond the wheel arch !!
My immediate thought is to get the back of the hubs machined down.
Has anyone any experience of this job ??
Is a no no or OK can do ??
Sorta the opposite of fitting spacers I guess !
it all depends on the thickness of the wall where the nut sits at the bottom of the counterbore.
if there is plenty of meat in there then its possible. otherwise you may have to go for a narrower tyre to give the impression that the tyre is under the arch eg so it tapers in slightly. imo
Seems to be completely symetrical .. like a built in spacer.. about 30mm thick, so that sounds good then
Cheers mate
if there is plenty of meat in there then its possible. otherwise you may have to go for a narrower tyre to give the impression that the tyre is under the arch eg so it tapewrs in slightly. imo
Took another look and measure and it cannot be done
So wide arches it is then ...
Cheers mate
Might do that ....how far can they stretch em Baz ??
Hey Joely dont be so Cruel and no I aint gonna show you nothing man
Any way I got 3 cars 20 wheels all 114 pcd so its just another wheel choice till i get the Zeds fat arse sorted !!
Z / RX-7 / Honda Legend
Anyway since when has a little extra width been a problem...darling !
Get the arches rolled ? much cheaper than a wide arse kit ?
