dodgy idleing
the last few times ive started the car first thing its sounded a bit rough, but not rattley, it sounds almost like its missing and exhuast is slightly poppy(if ya know wot i mean), and theirs quite a bit of white/pale grey smoke coming out of the exhuast especialy on the passenger side, but seems to settle down after about 10-15mins,
car seems to drive ok though after the 10-15min period, is it posibly the O2 sensors.
my cars a '90 twin turbo with 75,000 miles.
any ideas
cheers
si
This is usually caused by bad connections or corroded connectors on either coils, ptu or injectors
When it happens again, see if wiggling the wires/connectors makes it sound different or run better/worse.
Si - have you done the 02 sensor check? you can do it with your ECU. do a search - cant remember where it is but its the 2nd part of the ecu diags.
cheers jay, ill give it ago, if i can get my head round how to do it.
actualy after having a good listen to it this morning i pretty sure it aint missing, the engine feels nice and steady it just seems to sound beefy :confused: :D
