buzzing sound when door is open
where the hell is the buzzer for this it really gets on my t*ts .had to change window motor today and all i can hear is beep beep beep in my ears.
were your keys in the ignition?
no
does it if keys are in or out just when you open drivers door
if keys are in, it would be tell you door is open
but only works when key is in i thought
Mine only sounds with the lights on.
same as mine, yet buddahs chimes with the key in, and johnyboys chimes for any chuffing reason, even chimes when you slow down
It should only do it when your keys are not in surely ? Its to warn you that you've left your lights on when you leave the car(ie. when keys are removed)
Mine stopped doing it when I cut the speed chime wire.
mine doesnt do anything if i leave the lights on.as i found out 2weeks ago :headvswal
so where is this buzzer??????????
as t.pot said mine does it when you come when you stop ,but also does it when i leave lights on ,sounds like the call buzzer on a plane ,i just keep waiting for some trolly dolly to come past with duty free!!!!
Im sure they recreate the buzzer in Gran Tourismo
thanks guys for the help but where is it i know its under the steering wheel area :headvswal
Thats one fooking clever car, bit annyoing though i would guess, especially when knocking a sly one out
