Tension Rod Bush
my passanger wheel is 14mm forward i have looked around and cant see anything bent or out of place
i did a search and seems a few more people have had the same trouble and it is caused by the Tension Rod Bush worn out etc mine look ok but do you think i should change them or is there something else i can look at 1st
Good way of knowing if it is the tension rod bush is to look for leaking grease around the bush,
You should look for any signs of damage under the car as well fella as it might be sub frame if it has been in a bump ?? ( hope not tho )
I'm sure someone else will give more advice on this.
matt
