Springs question
Anyone know if it is possible to get uprated springs which do not lower the car's ride height?
Cheerz
Dave
try mancunian springs they'll make them for you and you'd be suprised how cheap they will be
Craig, I want better handling without lowering the car- since putting the Stillen front on I only have a small amount of ground clearance when driving up our pathway.
I think I need new springs cos my car sags on one side. I'm not too clued up on suspension to be honest wink.gif
Dave
Craig,
Adjustable shocks only adjust damping right ? If you need to change the spring rate then it has to be different springs.
Unless of course you get shocks that allow setting of preload (before they're installed) which will have a similar effect but will also reduce the length of travel, like having shorter springs.
Paul Bailey has a full shocks and spring kit,where you can ajust the height of the car around 900 squids.
Dave
Dave mate I know the feeling:
The reason you cannot see a shadow under my splitter is because there isn't one LMAO!
Bloody ground clearance!!
