Fuel pump dilemna and fitting in the tank
I bought one Z fuel pump on Ebay, it problably comes from an US TT version (2+0) as the strainer (bottom-end filter) is not attached to the pump itself but to a longer hose.
On the 2+2 TT, the strainer + pump is straight.
I just re-used the fuel pump unit itself.
I had some difficulties to put back the pump in place in the tank.
I think the bottom-end filter hits the plastic compartment (reserve) at the bottom of the tank.
I finally managed to push it inside but by forcing a bit, and I hope the bottom-end filter is still attached or the pump body is still attached to the rubber bracket.
Is there any experience about this ? Is there a special angle or trick to put it back inside the tank ?
Are you obliged to force it also ?
No posts to show
