s14 coolers
mentioned before but after real detail now...
How much work will it be to fit a pair of s14 coolers to replace my zed ones? the car has a 99spec front, but how much work / power gains... are these coolers ive got going to be worth the hasstle? Id luv a fmic but no spare cash and plenty of other things to do on the zed first, but was thinking these would be a cheap upgrade in the mean time.... guys are running upwards of 16psi on these coolers on 200s so they must be strong... but are they worth the hasstle?
i think you need to take into account the amount of air flow ( volume ) that can be pushed through them and not be restrictive , the S14 coolers may be able to handle 16psi but are set and designed for for a 2 litre lump the zed is 33% bigger than that and therefore will need more air flow,
probably not worth the effort since the inlet/outlets/endtanks need to be modified to be able to fit these.
There are a few Zeds here in Holland that use Renault 5 GTT ic's, but also a lot of welding and modifications needed to make these fit.
About the same size as the HKS ones.
not quite.
you basically have two *seperate* 1.5ltr engines.
the biggest restrictions is usually in the piping to from the intercooler(s).
Every 90 degree bend (and a Zed with smic's has many 90 degree bends in the intake system) is like adding over 15 feet of straight pipe...
hmm, seems its not worht the hassle, shame really as you can pick these coolers up for around 30/40ยฃ
bad news about the fmic, didnt realise the plumbing was that bad for them... guess il have to look around for good upgrade wing mounted coolers then....
Lymon said SMIC's not FMIC's in regards to extra pipework
opps, miss read that.... still guessing the coolers not worth thee work even at only ยฃ40 a pop?
