RichardS ·
I'm about to indicate how little I actually know about my Zed so far... :confused:
Had it 3 weeks, the front left tyre is looking a bit flat, it's running 205/50 R17s on the front and 255/40ZR17s on the rear.
Can anyone advise me what the tyre pressure should be on these on my Zed?
Many thanks, and I promise that one day I'll know something and I'll help someone else out...
