Maximum Efficient Boost
Hi Guys
Looking for you tuners to give me some advise.
I own a Uk spec Z32 series 2. About 4 years ago (3000 miles) i had a new Nissan short engine and 2 stock tubs fitted. I have recently fitted the following bits :-
Greddy Profec B Spec II Boost Controller
Blitz SUS Air Filter
Koyo Radiator
Greddy Intercoolers
Uprated ECU
Apexi BOV's
Megan De-Cat Pipes
Under Drive Pulley + Belts
RPS Max Clutch
RPS Lightened Flywheel
RPS Pin
New Thermostat
New Oil Pressure Switch
New Water Pump
New Oxygen Sensors
Earth Grounding Kits
What would be the highest boost i should use, to get efficient boost from stock tubs, hoping for 15-16PSI. They are brand new. Plan on running until die. then replace with say 530BB's.
Will my injectors supply enough fuel for that level of boost on stock tubs?
I have a new set of 555's. Is it worth while fitting them instead? I have heard that at 15-16PSI stock injectors are maxing out.
Plus, what pressure will stock internals take?
Regards
Kev
If you fit the Injectors, then 16psi would be an efficient setup. I would'nt run 16psi on stock injectors.
by 18psi the stock tubs are producing too much heat to be efficient, not to mention the shortened life span.
