Sticking dash down around vents beneath front windscreen.
As a lot of Z owners know the above is a very common problem on our cars with the heat making the dash rise around the vents and looking shite. I have removed the old plastic vents and tried a unibond serious stuff adhesive but to no effect. Without me spending silly amounts on those slightly wider carbon fibre replacements is then anything else that can be done?? e.g a strong adhesive which dries fast?? The only way I can see a successful job been done is removing the front windscreen which I do'nt really want to do. Any help or advice gratefull aprieciated. :bow:
i did this with my windscreen out, but did the grave mistake of cutting out some foam to make it stick better DOH!! dont do it, now it looks like the beach when the tide is out all ripples,
best bet is to stick to the guide like i should have done !!!
you could take the dash out or like i did glue it and gaffer tape it down ,ie stick the tape uder the hole and pull it up and over
where do you get the carbon vents???
chris c
