boost gauge fitting thread
trying to find a boost gauge fitting guide.
Mechanical one-mainly i just want to know where to put my T-piece in and a pic of where to put it in.
LHS of the balance bar, there are 2 vacuum feeds there where you can T into ;)
Any chance of pics?i just want to make sure i dont cut the wrong pipe lol!Just to be sure!
not the best pic but should give you the idea where ive done mine ;)
you can do as both are vacuum but i always use the one as your looking at the pic on the left?? upto you :)
Thanks again mate-just got to find a way of getting the pipe through the bulkhead now lol!
you can either drill a new hole above the accelerator pedal or you can feed it through the wing and into the car but its hard work and means you have to strip the inner wings out!! hence why i have a hole lol
Hole it is then!Probably leave this till weekend now.
Thanks again for the help
Go through the bonnet pull release hole Bud as its only an ickle pipe.If you then get one of those wire coat hangers and push that through carefully from the inside then tape yer pipe to it and pull it through.
Dont do a new hole. Feed it through the door and under the drivers side wing. I did that on mine. Just unbolted the wing at the top, and just moved it enough to get the hose through. No need for holes m8, this fits fine.
Plus I hate working with bodywork myself
thanks for the ideas guys
will decide tommorow when i have a go at it
The 20 quid membership fee pays for itself once again
Thanks to Bee Gee Vinz for his trick-worked a dream and the gauge fitted in minutes.
