setting for profec B2 with a FMIC
Just fitted my HKS FMIC.. and i need to know the setting for my profec as im not boosting as much as i used to....
So can someone that has a FMIC please give me the settings they are using... i want to be running about 16-16.5 PSI
Cheers :bow:
Sounds like you are pretty much up and running. Myself and Craig will be ready as of the next couple of weeks. Mines is running but need to fix the hoses at the top of the engine that I showed you when we met up.
Hope you find the settings you need. I guess 16-16.5 is better than 32psi??
sweet.... yea its all good, sooooo good to get out again! ill put some pics up l8r on in the week, will have to sort out a meet when we are all sorted....
im off from the 15th till the 26th so if you need some help fitting ur intercooler's then give me a shout! and ill be in my house then! :dance:
With stock turbos/injectors you really don't want to be running that sort of boost. For one thing injectors are maxxed out and you're out of the turbos efficient range by then. Try measuring the peak MAF voltage, you'll probably find it's actually flowing more at ~14.5-15psi than it is at 17. Ones I've tried it on have done.
Nice one, forgot you were moving house. You happy to be staying in Dundee instead of the base?
I am off too starting the 13th, got rally on 14th at Knockhill. Pressie for christmas. You can come along if you like, get a discount for £99. Its ood cos I dont go back until the 24th but I have my bike test booked on Friday 21st.
If you could meet up with me on one of the days I would be well pleased. I will also be fitting the transmission oil cooler while the front bumper is off.
Cant wait till all of this is done. You need a hand moving in. If you do I could borrow a van from work.
cool... anytime after the 15th im free as im in benidorm till then, so you can come over then as ill have all my tools etc....
