Kyb Ajx Shocks
can anyone point me at a dummys guide to adjusting these
as i've had them fitted today, i MAY not need to alter them at all
as ive only driven the car home since, but just want to be prepared
ie which way for altering front and back etc?
THANKS
THANKS
hi les
front is simple use the small scredriver and ajust on the top by pushing down on the screw and turning to the number required 2 is ideal
rear is simple,you may need to jack up the rear on the diff slightly,then go under and you will see a dial again it will have an arrow with 0-8,it will be set on 4 as standard which is medium-firm,turn dial by hand to ajust to required number
2 on the front and 4 on the rear is ideal,if you want it that bit firmer,then trail and error until you find the setting you prefer!
greg
you need a small flat bladed screwdriver and the adjuster is on the very top of the shock, in the centre. Basically if you look at it from the top there is a very small screw in the centre of the top threaded part.
thanks chps:)
lol i didn't realise they had numbers on the rears greg
as i had to dash to get the dog from the vets, or i would have stayed and looked, i'll have a drive round for a few days and see what they feel like
thanks again to you both;)
just thought if i need to alter is 0 or 8 firm?
thanks chps:)
IIRC 8 being the firmist
