solenoid valve
Just wondering where the wastgate actuator valve is located as i have just bought a limited edition black apexi avc-r boost controller and also where do i fit the pressure sensor also when all fitted what boost can i put it up to with out knackering anything up
Cheers johnboy
the wastegate actuator is on the front of each turbo, can be done but is fiddly to get them on and tight.
you can take a pressure point by T'ing into the balance bar pipe, one of the small ones on the left side of it :)
