speedo trouble again
getting a bit peeved off now. since purchasing car never had a good run in it yet, speedo neva worked. purchased set of clocks then speed sensor. still didnt work. left the car a few hours then bingo it started to work. unfortuatley next morning nothing on speedo again. thing is the mileage is working occasionally but no needle. took it out yesterday got to about 50 mph and the speedo started moving very slightly then nothing again , asif it were trying but gave up. every now and then there is a chime coming from the dash. all the electrics underneath seem fine. please can anyone help :smash:
Try this mate...
If your mileage is still clocking up but your speedo head isn't working then the chances are the fault is in your dash, as the speed signal is getting to your dash. If they both don't work at the same time then it is LESS likely to be the dash. Do you have a KPH-MPH converter, ie you have a J spec. Check all the wires around this.
If this is still not the problem check all the connections are clean and making good contact, especially the one on the speed sensor as it will be covered in crap at this time of year...
Hope this helps...
are they the original dials? cos when i changed mine, i shoved the needle too far in(or not far enough, cant remember) and it wouldnt go around properly.
if not could you have bought a dodgy speed sensor cos i think the chimes the speed delimiter.
just a thought
thanks lads the clocks i put in are british clocks ,reading mph. my car is an import on a g reg . the clocks were working fine when they came from another car. the connections underneath are clean. can i disconnect the sensor to see if its giving a reading. am i right thinking the sensor when in drive sends a signal to the clocks and not the clocks to the sensor. cheers gary.
Yeah the speed sensor gives a signal, don't know if the zeds give a pulse (which increases with speed) or a voltage (which ingreases with spead), but both could be checked with a decent meter
However you would have to attach some cable to the sensor and run it into the car to check (or jack up the back wheels and do it stationary - but I would not fancy doing that :nono: )
thanks marty ill try that i will be able to get the car on some ramps with a jack to prop the rear end up.
