rubber blanking plugs on turbo elbow
hi all, i have 2 blanking plugs one left one wright on the turbo elbows i think, both made out of rubber 1" dia, with a jubile clip holding them in place, they have rotted, wood this cause any problems with boost if i rev the car up to produce boost and then let go with my hand over the hole it sucks on my hand and where can i get 2 new ones from
if you remove the front panel they are there one left of the rad and the other right of the rad .
THANK'S MANSON :)
sounds like the blanking valves on the returns from the recircs... put on when dump valves are fitted. Demon tweeks sell aluminium ones - based in Wrexham, so not to far depending on where you are in cheshire...
thanks, wold this problem cause bad boost , this is on tizers old car.
