my lights
they have gone off, well the headlights have, ive tried changing the master switch, that didnt work have checked fuses under bonnet (uk car) they are ok, when i switch them on slowly the main beam flashes slightly
is there an earth anywhere that could be corroded or come loose, also when i put them on all the dash lights go dim and a red warning light that says lights comes on for abpout a minute then goes off
any ideas
cheers
Allan
i have a torch you can borrow..we could stick it on your bonnet ;)
(not much use again!)
at least you replied lol :mac1:
check the fuse's in the drivers footwell bud i had same prob and there was a fuse blown in there
i cant find the fuses there, dont think uk cars have them, mine is under bonnet
my car is uk and yes they do have them look towards the front of the car on the plastic pillar panel right by the side of the acelerator pedal) you'll see a pull off flap fuses are under there
I doubt its a fuse if your getting a flash of light mate, i would say its an earth fault, easy way to test, run a new earth from battery to earth on lights and see if it works
z lights earth through the relays i'm guessing it's one of the footwell fuses i lost all my lights apart from 1 main beam that either stayed on or flashed turned out it was a fuse in the footwell i think it was a 10a
just found it but its too cold to check the fuses, will do it tomorrow at work
there is also some spare fuses on the other side of the cover, so im guessing that this cover aint been off before :hyper:
cheers guys
If its uk it will tell you what the fuses are for on the little plastic cover you took off ?
it does say, but i still aint going out in thne snow
also got a hooge hangover :duffer: :headvswal
