Doing shocks now - advice please
From this guide:
http://web.ukonline.co.uk/rbagwell/rearshocks.htm
come the attached pic.
This is what my shocks look like at the top, it says remove the centre nut before you take the shock off, which makes sense as the actuator bracket won't go through the hole.
But is this the centre nut that hold the springs on which other guides tell you to take off once your spring comporessors are on? Or is there another nut below holding the spring on?
Cheers,,
Matt.
Call me dumb if you like, but whats the electric adjuster for and is it standard?
its standard on uk models i believe,it adjust suspension from sport to soft via the handbrake lever or something like that
The reason I asked was sometime in the future I was going to fit a set of Tein with the EDFC and if i had it already there was no need.
