nzr IT question
Hey chaps my pc has taken to opening links in a minimised window can just see title bar, I then have to restore it to read, getting a bit annoying I have looked at my internet set up and can not find any reference to opening links minimised where do I look is it somethink else?? even if I open as another page its the same ...help
Oh and when I am line now the monitor keeps going slightly puple then ok??? but only when on line. helpppp
Jeff TT
All I can think of is the window has been manually reduced and then youve closed the application so it will reappear as a default setting when reopened. Try opening explorer, when it appears as a title bar only, left click your mouse on the border and drag window to approprate size. Close explorer and then reopen.
monitor sounds like it could be on the way out mate!
Well done Bigroy!! you were spot on all okay now and also found monitor cable loose.
Oh by the way Matt the lad said you are a big fairy but I said your the the man and no way would I disrespect such a nice big armed guy as you. ( Any one seen Matty ?? biggrin.gif)
Blimey thats a first, 8 years in IT and I finally fixed a problem!!
Matty u big girl, bet u drive a manual?
