Switching hard drives
Hi All,
Just wondering if anyone knows of an easy way of switching between 2 hard drives. I'd like to be able to have 2 bootable hard drives that I can switch between. Not a problem if I have to reboot the system between them but I need to be be able to just flick a switch or something to change drives.
Vijay
Vijay, Im sure you can get a cradle or caddy, which sits in one of the front bays, and you can unplug your drive, and insert another.
Have a look on http://www.scan.co.uk usually where I buy my bits and pieces from.
Barry
What OS do you want to run mate? Most (Xp, linux etc) have a boot manager that will give a menu pointing to where the OS is. You can just install a second HD as normal inside the machine and install the second OS where ever you want it. No need to spend money on anything fancy then, unless you want to be able to remove the drive that is??
I run two OS's off of a couple of old small drives that I have in the computer. I then have a newer bigger drive with all my documents, music etc on. This can be seen and used from both OS's.
Dave
Once you've installed the 2 OSs on each Hdd, you can edit the boot.ini file so you know which is which e.g. :-
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Family Windows" /noexecute=optin /fastdetect
multi(0)disk(1)rdisk(0)partition(1)\WINDOWS="My Porn Installation" /noexecute=optin /fastdetect
:D
Cheers guys. Both drives will be running XP. The operating system sounds perfect but can I easily swap between the 2?
Vijay
Vijay, even simpler, many MBs allow you to choose the boot device dynamically on startup. The key to activate this feature is usually F12, but this depends on your MB/BIOS combo...
Steve :)
'93 UK TT Manual
Hello Steve,
How do I set up the drives - master/slaves etc?
Vijay
Hello Steve,
Vijay
Will call you later bud...
Steve :)
'93 UK TT Manual
Hi all,
Right, I've bought 2 of these caddys via Ebay and have a problem. When I install my HDD in the caddy and boot up, it gets as far as the windows start up screen, then I get a flash of blue screen (fatal error I think) and then it restarts. If I plug my HDD back in as normal, it works fine.
Any ideas?
Vijay
