Retrim - Heat resistant advice
Just noticed on the adhesive spray its heat resistant to 50 Degs C.
ย
Is that good enough to use?
Personally I cant see it getting that hot but when cars bake in the sun I dont know what the leatherette temp rises to?
I think it was said that a brush-on contact adhesive was better than the spray ones. I used spray-on and it's OKish but not brilliant, so I'll be using the brush type when I change mine soon.
Cheers bud, Ill get some of that then
Is a temp rating of 50 degs C ok?
if you use a contact adhesive then make sure you thin it out it gives you more time to move the fabric you use.
ย
otherwise you can use an upholsterers glue there are different levels of tack on these but they are more expensive
