Quick Question
My radiator fan seems to be running constantly, what checks should i do? How do you remove the E.C.U. Water Temperature Sensor, do you just pull it?
David
Do you mean the CTS Coolant Temprature Sensor?? a yellow plug on a water pipe?? If so it has one of those fiddley metal clips you have to remove with a small flat screw driver, then it just pulls off and then you can clean the terminals with switch spray and one of those emery things woman use on their nails. HTH
Cheers speedemon, i think were taking about the same plug, right at the front of the engine bay, i'll tackle that one next. Is it a likely culprit for the fan problem?
