CD Player Connection
Me again!
Ive been posting 2-3 times a day this week! I did only get my car on Saturday!!
Anyway - i have the original tape in my Jap TT 2+2 at the mo, ive bought a new cd player and i want to change it but im presuming i need an adaptor for the Jap connector..anyone know what its called/number of connector and if halfrauds sell them?
Ed
Me again!
Ed
You need an ISO lead/adapter - more info here
CheerZ
Steve :)
'93 UK TT Manual
CheerZ
Steve :)
Cheers!
You will also need an aerial adaptor as Jap is a queer 2 pin thingy...
Me again!
Ed
My Jap TT has had the right connections fitted , but my ( Goodmans ) cage won`t go in the hole--I`ve scratched the corners to fook . Does the panel have to come out of the dash , or should I just put the ( cage-less ) head unit in the hole and hope it doesn`t fall in under heavy braking ? :headvswal LOL
Remove the centre console trim. Its only 4 screws. 2 under the blanking covers at top and 2 under the blanking strip below vents.
Thanks for the lightning response , Legrath :bow: Google had better watch out !
:duffer:
Brian
Yep cheers chaps gonna try mine this weekend, although i have a sneaking suspicion im gonna have replace speakers to cus they are v v crackly(?!) at the mo!!!
I did that , but the player still won`t lock into the cage ( I`m using the bottom slot ) . On top of that , I didn`t disconnect the battery in case I lost any settings . Result : Player doesn`t work , central locking doesn`t work on the passenger door , and the Clifford alarm/immobiliser is indicating a fault ( 2 Chirps , then 4 ) , and the clock doesn`t work now either :headvswal
heres the wiring code and what they do..
Ground - black
Accessories - red
Permanent battery - yellow
Rear right positive - brown
Rear right negative - black/red (2 of these!)
Rear left positive - blue
Rear left negative - black and white
Front right positive - orange
Front right negative - black and purple
Front left positive - green
Front left negative - black and yellow
Antenna - black and red (test these out because there are 2 black/red wires)
Ground - black
Accessories - red
Thanks mate . I actually connected all the wires to like colours , as the previous owner had them connected .
Gonna check the fuses now...if I can find a Japanese midget to get at that conveniently positioned fuse box under the dash :headvswal LOL
It was fuses ! Got CD working :dance: And clock :dance: and passenger door-lock :dance: :dance: :dance:
As for the cage , well , B*ll*cks to it , I`m not spending another hour wrestling with THAT fooker , I`m gonna " Let it LIE " :tongue:
Thanks for all the tips , guys
:bow: :bow: :bow:
