protoj · Tuesday at 18:48 1 day
guys , im going abroad for about 8 months and my zed is staying here in a garage. Does this pose a potential problem doing this ??? i.e when i get back and try to start it, the engine is seized where its not been run for so long . Or is there anything else that could happen if you leave it standing for a long period of time ????
jim
