8mm silicone - from smithy
Fitted some silcone tubing today... but can't see anywhere that uses 8mm?? I sort of remember someone sayong where it goes, but can't find it!! Someone please tell me - it's been doing my nut!
Rich
Rich, I am due to do the same tomorrow from the pipes I got from Smithy, hence I need to know as well. By the way, how did you start off, did you just go around in any particular order ? And how did you distinguish the sizes ?
no particular order - just started ripping them off as I spotted them!! A few are hard to get to, but nothing too bad!! Size is obvious when you've got them off...
prob best to start from balance bar, then there's a few by TBs, then hunt round for the others! I know smity's wating for someone to do some pics of fitting - so you'll be able to go back for the stragglers when this is available!
Rich
18 views - come on people! Gettin to the point of going outside to look with a torch!
isnt 8mm only used on a boost controller setup?
not sure... mine's not arrived yet!! Anyone agree/ got any other ideas???
Rich
8 mm is normally used for fuel and water lines around the engine... but I wouldn't use silicon hoses for fuel.
the water pipes at the rear of the plennum are 8mm iirc, you cant actually see these i only replaced mine cos they were leaking!!
hmm... did look at those, but there's only 1m in the kit - which doesn't look enough!!
