Defi kit finally installed
got around to finishing the install last weekend, only had the stuff since xmas!
Monitoring boost, fuel pressure, oil temp, oil pressure, water temp & EGT, using the warning light as both master warning on the sensors and as a shift light :)
shame about the flash in the last pic
Looks very nice James :bow: Hope to see it on Sunday bud (will bring your Greddy instructions ;) )
Steve :)
'93 UK TT Manual
Is that a shift light you have as well??
the shift light is the defi warning light. Will light up if a sensor warning level triggers, but can also work as a shift light
on the guage . can you change it to monitor different things ie oil temp oil pressure etc , ie change to display of oil temp then switch to water temps etc ??
gauge on the right is boost only, the display on the left lets you choose what else to monitor. Whole point of this setup was to avoid 7 extra gauges to watch, and the warning function will alert if they pass a threshold that i set. it can also record and playback sensor readings
:bow: I'm not the slightest bit jealous!! :)
