Whats this little back plug and how do you un clip it?
I need to take this pug off in order to remove the cam belt but how do you unclip it?? Cheers :duffer:
I think there should be a small metal clip thats inset into the plug near the CAS.
You have to pry it back a little bit on both sides (the metal bit) and then the plug just slides off.
Becarefull not to bend the metal bit too much although you can take them off and re-straighten it if need be.
Its the same style as the PTU plug I thunk :smash:
there is a thin metal clip going around the clip, you carefully unclip that by using a small screwdriver, you will see itnot all around completly, but has a small gap.
then the clip slides off mate, careful you dont drop the metal clip
Ah yes, comedy Nissan electrical connectors. Unfortunately I can't tell you how to get it off, only offer some sympathy as I had a similar experience with one of the connectors in the centre console when changing my shifter bushings. What I can tell you for sure is that it'll be a right bugger, and you'll probably cut your fingers up trying to get it off. :(
There right its a very annoying metal rectangular clip with a piece missing from it you have to get it off the plastic plug with a small screw driver be carefull as quite often thay ping and dissapear somewhere;)
