changing the standard radio
Thinking of upgrading the factory radio on my zed. Does the wiring have the standard isoblock connectors or do I need to buy an adapter?
you need an adapter mate :)
you will also need an aerial adapter, plug in ones are about £15! or you can get a solder type connector for about 50p!! :D
FAQ
only thing to note is that I dont think the DIN surround will fit once you have swopped the headunit out. Unless anyone knows where you can get them you will end up seeing a small amount of the cage around the head unit...
not huge issue but is slightly annoying..
