chaning gear/dif oil
Ive done gearbox mt90 undo bottom plug with a half inch bar or rachet making sure first you can get the side filler plug out before draining oil.This oil will gush out fast make sure you have a big container.Let drain for 10 mins then refit bung .Filling from the side some gearbox oils has a tube to fill mt90 is just a bottle so a brought a syringe with long tube from machine mart £10 made job easy .I belive rear diff is the same principle as gearbox.
But how did you get the car in the air and level???
i eat 3 cans of spinach start an argument with the wife and go outside and kick assss :rant: :rant:
idealy you want to be on a ramp or 2 poster,or at least axle stands on the front and the rear so the car is level and safe enough to work under,ramp is much easier though,those bungs on the gearbox can be very tight and lying on your back with a breaker bar isnt much fun,ramp all the way ;)
