whining in 2nd gear
ive got a slight whining noise in second gear, its not present in any other gear,
seems to be coming from the gearbox/clutch area. car seems to be driving fine
cheers si
Could be the same problem i had on mine in 2nd and 4th, noisy main shaft bearings in the box, i've just replaced all the bearings in the box and replaced all the synchro's too to save having it apart again later on. A full set of bearings from Nissan was about £330.
Symptoms were a whining under load and at idle but disappeared with the clutch down.
Baz
Get the GB oil changed. MT90 is the lube of choice.
i only changed it about 2 year ago
how often should it be changed?
their doesnt seem to be any signs of a leak
check the rubber gators underneath gearstick,remove gearknob and centre section,and check if 1 or both gators are split,what will happen is when you enter 2nd gear it leave a gap between the road and the transmission tunnel,creates a whining noise,worth a look seen it a couple of times,dont condemn the gearbox yet ;)
