Engine cutting out
Problem :- engine cuts out at traffic lights/junction, not every time just occasionally, and will not restart. Ignition O.K.
I have found that if the pressure is released at the fuel filter, the engine will restart and run O.K. Any ideas ??
check the FPR (fuel pressure regulator) and/or engine temp sensor.
Thanks, lymon. Would faulty temp sensor cause the electric fan to run on normal temp ?
yes, as soon as the yellow connector (i think) for the fan temp sender is disconnected the fan comes on regardless of enginetemp
