kmh mph chiming
Can you just bung UK clocks in and throw the KMH ones away? Reason - I have a set of UK clocks, and my new import still has KMH.
And how do I get rid of that bloody chiming that I can hear when speed is over a certain level??!! :)
been searching - may trry swapping over dials - unsure if I can put a uk series 1 speedo gauge in my pod and it would read correctly.
Still cant find the chiming. . . . .
Take the top of the dash off, and there is a black box with a connector I think...disconnect it.
Glad I read this now cause I wondered what that noise was when I was on my race track...
You may need to swap the dials over in the housing if you have a Series 2 car with Series 1 UK clocks, pretty straight forward job and you may find once fitted the chime goes off whenever you stop, just disable it as in the previous post. Richard.
Cheers guys.
so if connectors on back of dash pod are different just swap the speedo gauge over - yes?
Secondly - what do I do about the odometer, will that still clock up in miles or KMH.
Ill take a photograph for proof of mileage before and put it into the records.
