Anybody know if these are avalible anywhere? The 3 pod gusge that sits above the air vents in the center on the dash?
russ (300zxstyling) took over a lot of Nisstek stock and ownership rights. Not sure about the Interior bits though.
zcentre do similar dont they?
No the Nisstech mimicks the original clock consol but smaller and sits on the dash above the vents. It looks verymuch like an OEM extra. The Z centre console is a copy of the ab-Flugg. It runs from the top of the original clock console way past the passenger air vent, then down over the vents.
The Nisstech houses 3 clocks the Z center houses 6 or 5 clocks depending on size.
Didn't like the original Flugg and my opinion hasn't changed.
yep, do two types. one stands out from the pod the other is sunken. should be getting the sunken one on Friday so will posts some pic's up
any ideas on costs russ? i really want one.
will have on friday and some pics :)
I like this one so much that Iยดm going to do a copy of it that fitts in the LHD Z32...
sorry guy, a bit more R&D needed
russ, are you doing the drivers side pillar set to hold 3 gauges?
not yet mate
