clutch pedel
when i press my clutch it.. it goes about 3/4th the way down... then make a clicking noise.. which you can feel as well..... its really weird.. clutch is not slipping... and its ok.. but i am kinda concerned.... its only just started doing this. what could it be.
The clutch pedal rod is adjustable, check the lock nut has come loose and the rod adjustment moved, also have seen a problem with the pedal assembly wearing where the clevis pin fits through which gives an elongated hole and the symptoms you have said, a replacement pedal will sort this, however we have done many successful pedal repairs by removing the assembly welding the hole up and redrilling it with a fresh hole.
Jeff TT
do you have any pics of what i need to look for.. i am not mechanically inclined... as luke will tell you... lol.
is this something i look for inside the car.. or outside...
is this under the car...
sorry to be daft with my questions.. but i really am not a mechanic in the slightest...
ok shall i take this to my nissan garage?? is it easy or difficult.. i guess I should ask.
You need to look inside the car, put the seat right back and with a torch take a look at the clutch pedal close to the top, you should be able to make out the 14mm locknut on the rod that connects the pedal to the rest of the system, sure some one posted a picture here recently and it showed the exact thing, will see if I can find it and be back in a little while.
Jeff TT
Ok found it, follow the link.
clutch adjustment
Jeff TT
Jeff your great... (everyone is great) but thanks.. seems the rubber is the problem... possibly the link... I figured it wasnt the clutch.. so I need to get it to someone who can fix it... Another opertunity to meet more members... and traders....
great for my social life.. hard on my pocket.. lol
