NZR Laptop harddrive
Help, my laptop is fooked, believe it needs a new harddrive. It did have a 10Gb IBM Travelstar, any suggestions where I can get the cheapest replacement. I am also led to believe the laptop is adaptable and will accept larger storage drives.
PK1 may have cheap kit...
The laptop will likely take any size of drive as long as it physically fits. Need to keep an eye on the heat though as the new drives generate a lot of heat...
Thankyou, been looking on Ebay, but some appear to have different current and voltage specs.
The Travelstar range is manufactured by Hitachi. I can get 40GB Travelstars (2.5", 5400RPM, 8MB buffer) for about £40 plus VAT.
Steve :)
'93 UK TT Manual
Steve :)
I saw that they now make them on the IBM website. Any idea what the voltage and current specs are?
Technical Information
Storage Capacity 40GB
Heads 2 Physical
Discs/Platters 1
Bytes per Sector 512
Drive Performance
Data Transfer Rate 493Mbps Internal Maximum
100MBps External Mode 5 Ultra ATA
16.6MBps External Mode 4 PIO
Rotational Speed 5400 rpm
Seek Time 12 ms Average Read Typical
Latency 5.5 ms Average
Buffer 8MB
Start/Stop Cycles 600000
Interfaces/Ports
Interfaces/Ports 1 x Ultra ATA/100 (ATA-6) IDE/EIDE
Reliability
Shock Tolerance 300Gs @ 2 ms Half Sine Wave Operating
1000Gs @ 1 ms Half Sine Wave Non-operating
Power Description
Input Voltage 5 V DC ±5%
Power Consumption 5.0W Startup (Maximum Peak) (Typical) @ 5 V DC
2.0W Read (Average) (Typical) @ 5 V DC
2.0W Write (Average) (Typical) @ 5 V DC
0.85W Active Idle (Average) (Typical) @ 5 V DC
0.60W Low Power Idle (Average) (Typical) @ 5 V DC
0.2W Standby (Average) (Typical) @ 5 V DC
0.1W Sleep (Typical) @ 5 V DC
Environmental Conditions
Temperature 5 °C to 55 °C Operating
-40 °C to 65 °C Non-operating
Sound Emission 22 dB Idle (Typical)
24 dB Operating (Typical)
Physical Characteristics
Form Factor 2.5" Internal
Dimensions 0.95cm Height x 7cm Width x 10cm Depth
Weight 95 g Typical
Miscellaneous
Additional Information Max. areal density : 70 (Gbits/sq. inch)
Recording zones: 16
Fluid Dynamic Bearing Motors (FDB)
Applications:
Notebook systems
External storage
Multi-media
Digital audio
Certifications & Standards RoHS
Warranty
Standard Warranty 3 Year(s) Limited
Parts Warranty/Labor 3 Year(s)
Steve :)
'93 UK TT Manual
